Have you checked with JC Whitney?
They have a pretty complete selection.
Carpet & Headliner
- flyboy2610
- jor
re: Carpet & Headliner
Years ago I bought some stuff from JC Whitney and it was really junk. I've stayed away ever since. Maybe they improved? Thanks for the reply.
jor
jor
- binder56jd
I have used a product that goes by several different tradenames- fiberglas reinforced plastic- can be purchased at home depot or lowes or others- save your old liner for a pattern- will last very well- i also put some foil covered styrofoam sheeting in first due to the sun beating down JD
now serving #235
now serving #235
ok i have the thre rubber mat but still.......mine is a 8 inch transmission hump and all the replacement mats i've found have had holes cut in them for floor shift manual transmissions. Does anyone sell auto versions?
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
This is where I might buy my carpet from: http://www.auto-interior.com/
They seem to have high-quality stuff. About $120 including shipping for my truck w/ cruisomatic transmission. They seem to have different carpet for C6 tranmissions w/ high hump floor. A lot of color choices too. I would call them to make sure.
Get your carpet from stock interiors .com 80/20 loop with padding molded and they send you color samples. They sent my samples in 3 days and carpet was here in a week 129.90 with shipping.
- 460 crew
I ordered mine form MAC's and it came from here http://www.accmats.com/ It's a Loop with insulated backing for my crew from front to rear walls and has held up to dirt and mud in the construction field.
- 71 LONG BED
Thanks Binder56jd! I like that idea, now I have another "to-do" on my list!I have used a product that goes by several different tradenames- fiberglas reinforced plastic- can be purchased at home depot or lowes or others- save your old liner for a pattern- will last very well- i also put some foil covered styrofoam sheeting in first due to the sun beating down JD
John Member #1549
