The bed is getting the floor moved up 4 1/2" to clear the fuel tank and the cross member, then I will fab some mounts to bolt the bed down once and for all. The air system is almost done but I still have to make two 6x6x30 square tanks, the reason I am making them square is because the round tanks are 8" tall and will rub on my wheels. After this is all done I will start working on some custom scissor hinges for the hood and after that's done the truck should be all put together and ready for disassembly so that I can start paint the frame and under the cab and bed.I took some pictures of the day that I drove the truck home from the shop but the pictures were taken at night so you won't be able to see any detail. Enjoy
The tank is 24x29x10 it came out to be 30 gallons.
Here is a before and after with all the components on the frame.
This was done friday night 7-28-06, I decided to remove the entire floor and do a smooth floor out of new sheet metal with some compartments for storage.
