Thursday my son ran out of gas and I took 5 gallons to him to get home on. The next morning the fuel pump quit. I had one and he tried to put it on but that didn't work to well so Friday morning I pulled it off and reinstalled it correctly. He had pulled the p/s pump off for some reason so I decided this was a good time to c/o the horizontal oil filter adapter with a car type vertical one I had practiced my polishing on. Well there is not room for the filter to go on once its on. I just jacked up the engine, put the filter on and I will change it back next oil change. It does clear once its on by about 3/16"
This morning I didn't like how the brakes felt and I knew the right wheel cylinder had started leaking so we went to NAPA and got rear shoes, rear wheel cylinders and 3 cans of brake cleaner. That went well but it took all morning. The brakes are fine again as in all 4 will lock up if you mash hard enough in testing.
The good thing is this cured the "want to do something to it" feeling I had.
