aftermarket radio install questions
68f100ranger
Post by 68f100ranger »
alright im wondering what you guys have done for speakers when you intall aftermarket cd players? where is there room to intall door speakers or subwoofers?
thanks
__________________________________________
68 Ford F100 Ranger
70 Mercury Cougar
89 Ford Bronco
gonzalo medina
re: aftermarket radio install questions
Post by gonzalo medina »
Well for starters if you are going the door speaker route, find metal pannels to cut into and please don't harm the actual door skins.
gonzalo medina
Well for starters if you are going the door speaker route, find metal panels to cut into and please don't harm the actual door skins. Another Idea is to simply upgrade your factory with a hotter one. I know lmc and npd offer after market replacments that should be better the original. Something else to keep in mind is with bucket seats, you have a huge space in the middle for a huge subwoofer. Hope this helps :)
jor
Post by jor »
Here's three possibilities (sorry Gonzalo).
jor
68f100ranger
hey thanks for the sugestions. that gave me a few ideas on what my options are.
68 Ford F100 Ranger
70 Mercury Cougar
89 Ford Bronco
Vermonter 67
Post by Vermonter 67 »
On my truck the headliner was shot. I made a plywood base that slits into the rim on the ceiling of the cab. I then mounted speakers into it and covered iso now I have the speakers in the roof.
More often than not, it's often more, than not...
mrsnicks
Post by mrsnicks »
Some trucks also came with a Dash speaker and factory bracket under the dash. You can find a bracket in some of the old trucks or make your own.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Dropped 68
Post by Dropped 68 »
Rod Doors makes custom kick panels, and door panels for the 67-72. I think the kick panels have speaker provisions in them. I think they run about 70 dollars for the pair on the kick panels. As far as subs go, once you get rid of the gas tank behind the seat there's plenty of room. I have two ten's tight now, but eventually will have twelve's and possibly a custom fiberglass enclosure. As for my speakers, It's not permanent, but I have some pioneer enclosed boxes ( the ones w/ a mid, and two tweeters) in a plastic enclosure mounted on each side of the rear glass. Sounds good but doesn't look as nice as I want for the finished product.
Good luck, Charles
Build, Destroy, Rebuild.
68f100ranger
thanks for the idea. is there a list of vendors that we can get parts from for our old trucks somewhere? might find some stuff that i cant life without.
thanks.
68 Ford F100 Ranger
70 Mercury Cougar
89 Ford Bronco
