Help
Help
I have a 72 ford f250 camper special/390 2bl. It has set awhile, It has a remanufactured block (7000 miles on it) I put a new voltage regulator on it, alt, starter, cables, grounds from engine to body, relay. battery. I tried cranking it and it won't fire. I got gas moving through the line to the carb. It turns slowly while jumping and the cable from the reg to the starter gets hot when I crank it. I started it last spring and had a hard time. After it ran awhile, I shut it off and it wouldn't even turn over. Please help, trying to get it ready to sell cheep Robert
- splavin90
neutral safety switch?
and- that sounds really bad that your starter cable gets hot. get a bigger wire before you melt away that insolation and start burning things up and catching things on fire
put a teaspoon of oil in each cly
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
Help
I don't think it is the nuetrial safety switch. It trys to turn over but it's like the battery died. I am concerened about the wire from the starter switch on the fender to the starter getting hot. Does that mean that I am getting too much power from somewhere and that it could do further damage?
Thanks,Robert
Thanks,Robert
- kknip
Do you have the battery ground hooked directly to the block?If so,is the block clean under the cable?Rust and corrosion cause alot of resistance and will make things really heat up.Make sure all contacts with any cables are real clean and free of rust and corrosion.If you don't have any fire,I would check for power at the coil,points contacts,distributer cap and wire ends for corrosion.What do you mean by "jumping",jump starting with cables I'm guessing. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Soitenly! Oh,a wiseguy!
You knucklehead!
![Image](http://upload7.postimage.org/222426/3gears.jpg)
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
Sounds to me like you might have your timing a bit too advanced....when it's advanced too far it'll crank hard as you describe. Try backing it off a bit and I'll bet it'll crank over a lot faster.
And as mentioned, the battery ground strap needs to be to the block, not the frame, and there should also be a ground strap which goes from the back of the block to the firewall.
Re: Help
I use a meter that can measure Ohms in an AC or DC live circuit but you don't need a $400 Fluke to do this work.
tach, dwell, temp, graphs, pics & volts, amps, more.......... %^&* looks like I got screwed . $400.00 from what place. you better not say off a snap-on truck
![Mad :x](./images/smilies/icon_mad.gif)
WHAT ?
