I have a new shift collar for my 68 ranger, auto. I already painted it and was just curious if I will need any specialty tools to swap it out.
Thanks, ratfink
New shift collar
- ratfink
New shift collar
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
re: New shift collar
A paper and pen. To make wire diagram of plug on column. Where
wires go in plug.
wires go in plug.
I just replaced mine, The hardest parts for me were, Getting the pin out of the gear shift selector. Then on the end of the shift tube there is a spring. i used duct tape to hold the new collar down so I could use both hands to put the the housing that holds the turn sig. switch. I also broke the neutral safety switch lever on the shift tube. The new shift collar was tighter, I tried to remove it to apply some grease and.......snap.
- rjewkes
Sounds like it needs a pre lube before install.
