So I did the weatherstrip and windows yesterday
DMikeM
Post by DMikeM »
Man that's nice! :D
My truck is a '70 F250 XLT and I think I just removed the original rubber from it's channels.
It's so quiet and comfy now I just want to get a sleeping bag and take a nap in the cab. I guess the next fix up will either be the floor mat or the door panels with new handles.
I thought I would never get that glue off my fingers. :doh:
1970 F250 Camper Special 4x2 390cc
Big D's 69
Post by Big D's 69 »
Yeah little things really add up thats for sure.
foghorn
re: So I did the weatherstrip and windows yesterday
Post by foghorn »
Ya i already did my door seals next will be the window felts and wing rubbers. We have a local salvage yard that sells the aftermarket rubbers in north tulsa.
foggy 8)
Jake11
Post by Jake11 »
Come over and do mine. I'm waiting. 8)
green71F100
Post by green71F100 »
I need this bad. where did you get the stuff and how long did it take?
it shouldn't take very long to do. you can get the rolls of the stuff almost any place that sells aftermarket parts. you might even be able to get it from the parts store. i know you used to be able to get it there.
CA180
Post by CA180 »
Hey foggy... where is it that you are talking about that does the rubber inserts? I live in south tulsa, and work downtown. I've been looking to get new seals.
Let me know, thanks!
foghorn
Post by foghorn »
North yale auto salvage . If i had my salvage guide i could post the phone number for you. But alas i left it in my dumptruck at work. I was using it to make some calls one day and forgot to bring it home.
Foggy 8)
DMikeM
Re: re: So I did the weatherstrip and windows yesterday
Post by DMikeM »
green71F100 wrote:I need this bad. where did you get the stuff and how long did it take?
I got the Door kit from JCWhitney and the window kit from buycarwheels.com Took 3 days shipping each. The installation took 3 hours on the first door but the old window channels were stuck real good. The second door might have took an hour to do. I also greased the window crank channels and replaced the lock arm retainer clips.
It's so quiet and tight now. My ears even get stuffed when I pull the doors closed if all the windows are closed.
cooltoolguy
Post by cooltoolguy »
weather strip whats that? :eek: mine fell off . its a little breezy but it keeps the exhaust fumes from building up in the cab :thup: that way i wont pass out :zz:
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
DMikeM
Post by DMikeM »
cooltoolguy wrote:weather strip whats that? :eek: mine fell off . its a little breezy but it keeps the exhaust fumes from building up in the cab :thup: that way i wont pass out :zz:
Actually before I replaced all the rubber I would get fumes. Now they are gone. :thup:
