Help some moron wired my reverse lights into the brakes
- rjewkes
And my brakes into the reverse system. How the heck do you get the plugs on the fender apart so you can loosen the harness good enough to get it out of the instrument cluster hole far enough to start a rewire?
or atleast far enough to drop in a good spare harness?
- rjewkes
thanks i got them loose now i need to pull the drivers plug through the hole and get enough wire through the hole in the dash to get a good look at the wiring.
- rjewkes
cool i'll try it in the morning. almost to the point i wanna use her for parts and get a truck with good wirting lined up.
- rjewkes
not yet i'm hoping to save it for another project. But if i have no other choice i will.
- rjewkes
yup its in the dash its just realy close to the firewall.
somebnody thought the two that come off the backup lamp harness/neutral switch went to the brakes and vice versa. they then wired around the non working turn signal who's only fault was that undersized screws where used to reatach the socket to the bed.
- rjewkes
Ok so it wasn't in the dash but there where a few wires there that needed attention. Besides it made it easier to reach the wires for reasembly.
And when it was all wired and double checked with my test light it was your suggestion Bluef250 that helped me figure it out.
