ISO relays???
- xxxtina63
ISO relays???
I recall reading a couple articles about incorporating a generic ISO relay in things such as the headlight harness to improve the voltage actually getting to the headlights, thus making them brighter. Has anyone ever tried this, and if so, does it actually work?
My FORDification Photo Album
- 67highboy
re: ISO relays???
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
- ICEMAN6166
re: ISO relays???
it is one of the best things you can do to your truck.you can even set it up so hi and low beam are on at the same time.
- adrianspeeder
re: ISO relays???
Done it fer two of the trucks now and it should be a mandatory mod for pre '92 Fords.
Some digarams I've made:
With fog lights
With combined high and low beams and a toggle switch to replace the floor switch.
Adrianspeeder
With fog lights
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- ICEMAN6166
re: ISO relays???
lots of drawings to choose from.i used this one the first time.
not just a drawing, and theres a good explanation if you have not done this type of thing before.
http://fordtruk.com/index41.html
- xxxtina63
re: ISO relays???
Sweet!!
This is just the info I was looking for.
Thanks everyone!
