LIGHT?
CA180
LIGHT?
Post by CA180 »
What is the light at the bottom left of the dash for? I wasnt sure, cause i've never seen it come on. I thought it may not be original. Let me know if anyone has any thing.
Thanks
kknip
re: LIGHT?
Post by kknip »
It is the brake warning light,it comes on in the event that pressure is lost due to a wheel cyl blowing or line rupture.The switch is on the distribution block in the frame rail under the master cyl.It should come on during cranking,but go off when the engine starts.Maybe a bad bulb.It suppose to have a red lens with a chrome bezel over it.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
CA180
Post by CA180 »
Ohhhhh, ok, that makes sense. Yeah, it no werky. I'll have to check the bulb. Thanks alot man!
the light won't come on unless the brakes aren't working right. it is suppose to come on when the key is turned on but some say that it doesn't
Supermike
Post by Supermike »
Is this light supposed to come on when the parking brake is applied?
no
only if the hydralic brakes have something wrong with them.
FLATBEDFORD
Post by FLATBEDFORD »
Mine's been on for almost a year now. The brakes have been bled repaetedly and seem to work. I've gotten used to it.
My Photo Gallery
center the brake valve to make it go off.
FLATBEDFORD
fordman wrote:center the brake valve to make it go off.
I've gone through the centering procedure many times and the light is still on. Maybe its the switch?
My Photo Gallery
it could be. or the wiring has been messed with and now its on forever.
Big D's 69
Post by Big D's 69 »
Yeah mine has been on for the last 5 years that I have owned or known about the truck.
when you get to 10 sell.
