Door handle rattle?
Door handle rattle?
I searched last night and today and didnt really find anything relevant.
Anyhow, the drivers side door handle in my 72 bump rattles non-stop. It gets irritating as crap! I stuffed a rag down in it to shut it up for now, but i wanted to know if there was a fix for it, shy of replacing it. Let me know if you guys have the same problem, and what you did to fix it.
Thanks in advanvce
Thanks in advanvce
- ICEMAN6166
re: Door handle rattle?
its either wearing out the nub that is on the inside or the screws have come loose. need to remove the armrest and see.
- Big D's 69
My old one rattled and once it completely wore out and wouldn't open anymore then I bought a new one and no more rattle.
I'd first diagnose the problem to see what's worn out. It could be something as simple as the two small nuts that hold the handle to the door being loose. Tightening them up could be all you'd need to do.
Yeah, i tried tightening them up. Didnt work. I had to replace the pass side outside lock mechanism and got to looking at how it worked. I checked the drivers side, and as far as i can tell everything looked ok, just rattles. Are the drivers side and passenger side interchangable? Prolly a stupid qiestion, but i wasnt sure. If they were, i might try swapping them and see if that shut it up.
Fordman, how much would you like for the handle?
- ICEMAN6166
no.CA180 wrote:. Are the drivers side and passenger side interchangable?
- wt4speed#2
Turn up the tunes
Tony B
Tony B
I would, but my radio is broke
Fordman, i'm gonna see if i cant possibly fix it first, but i'll PM you later if it doesnt work. Thanks alot!
