Anyone have a diagram or a sketch of the underhood wiring? Talking about the wiring harnesses that come thru the firewall and run down each inner fender. This truck was a roller when I got it, and pretty well stripped under the hood. So far it looks like most wiring is in place, but it seems like the alternator harness is missing - I think it would be wired off the passenger side. I do have an empty connector that it might plug into.
Any help would be appreciated. BTW, it's a 71 sportcustom. Just in case the wiring changed slightly year to year.
underhood wiring diagram
- bluef250
Here is a view of the wiring. The wiring between years did not change much. Look around in this area of the FORDification and the schematics for each part of the wiring are posted for the 1969.
http://www.fordification.com/images/sch ... arging.jpg
If you need the 1971 wiring do a search on the web for the wiring diagrams.
