are these the pieces that go in the door around the int. lock pull up thingie?
part no. 9
http://www.lmctruck.com/icatalog/fb/0018.asp
interior door lock ???
- ezernut9mm
- wt4speed#2
re: interior door lock ???
They appear to be .
Tony B
Tony B
- ICEMAN6166
yes they are.
- ezernut9mm
just making sure. i be needing them.
