Steering Wheel
GMan
Steering Wheel
Post by GMan »
Is there a way to determine whether your truck came with the horn ring in the steering wheel?
G
67 trucks had a horn button similar to the horn ring but it had no ring just the center part. 68 - 69 had the horn ring and button as one piece. 70-72 had a horn pad that went across the center of the steering wheel.
GMan
Post by GMan »
for the 68-69 the horn ring and button were on all three packages offered, the base, custom cab and ranger?
heres what kieth has to say about it. i know ranger had the ring on it. http://www.fordification.com/67-72ID.htm
Calvin Gunter
re: Steering Wheel
Post by Calvin Gunter »
Mine is a 67 Ranger and it came with a ring.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
GMan
Post by GMan »
Yeah, I read that which raised the question for me of whether the horn ring was standard in the Custom Cab or part of a package you could get for it. Mine came with the added gauges in the instrument panel as well as the nicer seat package so I would assume it also had the horn ring. Thanks very much.
what do your emblems say on them. that should tell you something more.
GMan
Post by GMan »
which emblems are you talking about? the previous owner put an aftermarket steering wheel on it and he is no longer around so I can't ask him.
on the body and the glove box maybe.
GMan
Post by GMan »
yeah, no additional help from them. Thanks for the quick replies; they help confirm my original assumption.
ezernut9mm
re: Steering Wheel
Post by ezernut9mm »
my 68 cc has a ring. gets in the way sometimes when "aggressively" turning the wheel tho.
manual steering?
ezernut9mm
fordman wrote:manual steering?
if you mean "armstrong" steering, then yes. the ring looks cool, but the button stays out of the way.
Supermike
re: Steering Wheel
Post by Supermike »
Steering wheels for all 1967-1970 models (pictured above) were the same and used a three-spoke design. The standard wheel (pictured above left) uses a simple horn button, while the Deluxe wheel available with the '69-'70 Ranger and Custom Cab packages incorporated a horn ring (upper right). The three-spoke wheel was used on '61-'70 trucks and on '60-'63 Ford Falcons
This is interesting... my 67 Camper Special has a horn ring, and it appears to be the original steering wheel. It matches the column, and I don't see any sign they've ever been removed or replaced.
In addition to this, my grandpa had a 67 Camper Special when I was a kid, just like mine. One of the things I remember about it the most? The horn ring! What kid doesn't like to play with the horn?
I believe the horn ring WAS an option with the 67's. Check out the picture for item #28 in this brochure from 1967...
http://www.fordification.com/lit/images ... re_p15.jpg
i always thought all 67 were a button instead of a ring. i guess i was wrong.
