"Diamond projection headlamps" ?????
two-bit
Post by two-bit »
Saw these listed on E-bay, was curious if anyone knows anything about them.
Just a random thought, anything has to be better than the old ATLAS beams. :lol: :lol:
Supermike
Post by Supermike »
These sound pretty much the same as the H4 conversions (like LMC sells) that allow you to use a more modern housing/replaceable bulb type assembly instead of the sealed beam lights we use today. I think the "Diamond cut" thing is just a trademark.
http://www.jcwhitney.com/autoparts/Prod ... 24/c-10101
adrianspeeder
re: "Diamond projection headlamps" ?????
Post by adrianspeeder »
Is anyone runnin' those new lights from the cover of the LMC catalog? Think they look cool and would work well on the '66 and '71 with the relay rewire obviously.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
marz68
Post by marz68 »
yeah you would want to throw some relays on it to cause just the lights them self with the stock wiring isn't going to do any good.
ICEMAN6166
Post by ICEMAN6166 »
relays will even make the old atlas beams a little brighter, because there wont be such a drastic voltage drop thru the factory wiring.
rjewkes
Post by rjewkes »
i have them but they are all 90/100 watters you probably only want a 55/65 set up. it was probably needing replaced anyways but i think the 90/100's cuased my ligh switch to kill over.
Tim P.
Post by Tim P. »
even with a relay system that 390nut is making the light switch would not be able to handle the 90/100 system?? Am i reading this correct.
adrianspeeder
Re: re: "Diamond projection headlamps" ?????
Tim P. wrote:even with a relay system that 390nut is making the light switch would not be able to handle the 90/100 system?? Am i reading this correct.
Don't think thats what he means. The relays only draw 30milliamps through the headlight switch instead of the 10amps or so from the stock bulbs.
Adrianspeeder
Tim P.
Post by Tim P. »
So with that harness and new headlight switch I could run the 90/100 upgrades
ICEMAN6166
i run 100w hellas on the roof of my trucks , they run thru a relay and use only a standard on-off switch so it should not cause any problem with the stock headlight switch.
adrianspeeder
Tim P. wrote:So with that harness and new headlight switch I could run the 90/100 upgrades
Correct. The common bosch relays are good for 30 amps. Ideally that would handle 12volts x 30amps = 360watts of power.
Adrianspeeder
Tim P.
Post by Tim P. »
Kewl :thup:
