My new CB
- wildcard
re: My new CB
It really depends on what you want it for and how much you want to spend. I have about $500+ in my set-up. That's because I used to want directions or whatever and those "big" radios would cut me out. So mine was for business as well as pleasure.
The best thing is to find a reputable shop and have it peaked and tuned. You can usually get reccomendations on the cb. Do you want a mounted antenna or a magnetic one? Magnetic ones come with coax attached. But you get what you pay for there. Mine was custom built at a shop near here. My coax was built in the same shop. I also have a noise filter on mine, and as I said, a 100 Watt kicker I got in a deal. I've had many compliments on my sound quality.
So, you could buy a magnetic antenna and hook it up that way to get started. Some Wal Marts carry them. Then if you want to upgrade from there, find a good shop and work with them on how far you want to go.
Good luck and help keep the airwaves clean.
Also, a good handle comes in handy. They call me Wildcard. What a coincidence.
Well IMO its hard to beat a wilson like this onen001pa wrote:Obviously, I know nothing about cb's. I thought you just hooked them up and turned them on. You guys know more than me so what should I get for mine?
I have a Royce 636. It is indeed NIB and looks like it has never been out of the plastic.
Give me specifics as to what antenna, cable, and anything else I need to install it.
I am looking for a good CB shop to check everything over for me but it looks like the nearest one may be more than 50 miles away.
http://cgi.ebay.com/NEW-4-MAGNET-SUPER- ... 0096998243
as far as a mount its up to you. This is what i have mine mounted with
http://cgi.ebay.com/PAIR-3-WAY-ALUMINUM ... 0096033145
This is what i suggest for coax and never the rg-56 or 59 junk
http://cgi.ebay.com/18-ft-ASTATIC-CLEAR ... 0096330765
You can also have the cb shop build you one of these with the hd coax if this is what you want
http://cgi.ebay.com/CB-Magnet-antenna-M ... 0087975559
Now if you want one of these it takes a bigger magnet to hold them
http://cgi.ebay.com/The-Viper-1-Snake-S ... 0094552119
Mine looks like the one above but its called a striker and has a lifetime warranty. If you want one of the big coil type and a magnetic mount i suggest this one it will not go any where with this one
This is just to give you some different choices to choose from.
Foggy
- n001pa
re: My new CB
That helps alot.
I am planning on putting a small pop up camper that I am restoring on it. It has a small slide out bed over the cab that may interfer with a single mount in the center of the cab so I think I will go for the mirror mounts.
What would be a good shorter antenna for the dual mirror mounts? And what should I look for in a splitter for the antennas?
Carl
"If less is more just think how much more more would be."
re: My new CB
IMO i would go with just one two cuts down on the power of the radio. Besides you cant get them far enough apart to work right. It takes a min of 104" to make duals work right. But if you just like the looks go for it. I myself like the monkey made or viper or striker atennas. The striker has a full life time warranty. Even if you break it on a tree limb they will fix it for free. Bench checks and resets are free also. They are made in okla city here in okla. and sell for $70. I paid a full $100 for mine with the hd mirror mount and hd coax 18' of it. If you go with the duals use a t connector and not the plugs like the one for a am/fm radio those lose some of the trans and rec for some reason.
Foggy
Foggy
- n001pa
My conceren was with the length of the antenna. I plan on driving the truck alot and would hate to always have to worry about every drive through I come to with the 70" antenna.
Would this be a good one?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... Track=true
I was thinking about it and maybe a dummy antenna on the other side just for looks.
Carl
- cghstrojan08
re: My new CB
I know this is a meter but how do you work it?
http://i9.photobucket.com/albums/a75/cg ... G_2253.jpg
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
re: My new CB
I got, finally, up to that CB World north of the Pilot. I had my cb peaked and tuned. I went from 4 watts to 27 for just $26.50.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
re: My new CB
Well if memory serves me right hook just the atenna to it to start with. Set to swr adjust try to get the lowest you can get. If it don't get any lower than 2 you may have to cut off some of the whip if it wont slide into the bottom part when the set screw is loosened. A 1.1 is the ideal setting you really want. Then hook to the radio and atenna turn to channel 1 and adjust swr again. Repeat again on ch 40. You might be able to goggle the model number and brand name and find a downloadable owners manual. Just remember i think its if swr is to high shorten it if its to low make it longer. You might have to call a shop just to make sure. Good luck in the search .
Foggy
Foggy
- cghstrojan08
re: My new CB
The guy went ahead and did the swr for me for free. He said that he got it perfect right on the dot.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- wildcard
re: My new CB
Congrats on the fix up.
- n001pa
