Short Time High Beams
ptodave
Post by ptodave »
Took old betsy out for a ride last saturday night. Headlights worked fine on low beams,hit switch for high beams and nothing.Replaced dimmer switch and now high beams work but only for about 5 minutes then nothing. Back to low beams seems to work ok. What do you think? Did some searching but could not find anyone else with same problem. Thanks. PTO.
Engage Brain BEFORE Engaging Gears
72 F-250 390, NP435, Dana 24, D60, 14b, 4.88s, detroits, 2 winches, 4x4 40" tires.
it might be a loose wire on the dimmer switch. or maybe it could be in the headlight switch itself but that doesn't sound like it. if you had a old dimmer switch they can get stuck and not work properly. but since you installed a new one that doesn't sound like the problem. wiggles the wires and see if that helps. it could be the dimmer is bad even though its new.
71PA_Highboy
re: Short Time High Beams
Post by 71PA_Highboy »
The other thing is an old headlight switch... the CB in the switch will usually reset and you will have flashing headlights if there is a problem... but stranger things have happened...
I would think floor dimmer first, wiring second, headlight switch third...
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
frankc67
Post by frankc67 »
Could also be the voltage regulator near the battery.
1968 Ford Pickup
1998 Ford F-150 extended Cab
2000 Ford Explorer
http://www.fordification.com/galleries/ ... ?pos=-1469
ptodave
Post by ptodave »
How the heck to you know if your NEW dimmer switch is no good? I replaced voltage reg about a month ago. Paid $9.00 for new dimmer switch from pep boys,LOL. Been a while since I replaced headlight switch,like to figure this ,gets real dark in the canyon I live in, need high beams.
http://www.fordification.com/galleries/ ... ?cat=10578
step on it a few times and make sure it comes back up everytime. if it does then you could put a meter on the iwres coming out of it and see if it puts juice through the switch.
flyboy2610
Post by flyboy2610 »
Are these the factory headlights or the new high power type you have to have a relay for?
ptodave
Post by ptodave »
flyboy2610 wrote:Are these the factory headlights or the new high p
factory headlights upgraded years ago to halogen,low beams seem to work fine its just the high beams.
adrianspeeder
Post by adrianspeeder »
Come see the light and do the relay rewire :thup:
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
is there a fuse holder on your passenger fender. if so check the fuse in it. maybe it blew.
ptodave
Post by ptodave »
fordman wrote:is there a fuse holder on your passenger fender. if so check the fuse in it. maybe it blew.
I will look tomorrow for the fuse,do not remember seeing one there but I will look. Thanks for all the help you guys. By the way what is the fuse for?
well mine has that fuse holder but it has never had a fuse in it ever. and my stuff all works. i think my truck might have the camper special wiring harness in it. that is the only harness i have seen that is suppose to have the fuse there. the reason i thought it might be on your truck is because supermike was having dash light troubles and that is where his troubles were was in that fuse. i was shooting tn the dark so to speak., just a sanother place for you to check.
rjewkes
Post by rjewkes »
could just be the ground behind the headlights.
kid
Post by kid »
Light CB is the cause my 350 did it until I relayed it high beams cycle due to the CB tripping. The switch to low beam caused the breaker to stay cool. Halogens are 55/65 Watts low/high stock was 25/35 and then the CB was set for 35 Watts * 2 for 5.385 Amps. So I tested the current draw to trip my new light switches CB and 9 amps was it. The highs on the halogens draw 10 amps plus the resistance in the wires, splices connectors and bad grounds added up to 11.4 amps needed. Pop went the CB.
If you have an Ammeter gauge there are two fuses under the hood for the gauge, one for each side 4 amps each.
ptodave
Post by ptodave »
So if I put the regular headlight (non halogen) the problem will go away?Is there a up graded light switch for halogen lights? Sure like the whiteness of halogens over the yellow of regular lights. HELP!
