Brighter Headlights - Even in broad daylight! (photo's)
Sharkdance
Post by Sharkdance »
Greetings all,
Thanks to 390Nut, Ive got one less worry for my 70 F250. (thanks Dude!)
I bought one of his relay/headlamp harnesses and got it installed the very next day after receiving it.
Well made product, easy to install, and a huge improvement over the stock headlamp harness setup.
Tools needed:
Drill
Drill Bit
1/2" wrench
screwdriver
Hardware needed:
3 sheet metal screws
5 wire clips (optional)
5 wire ties
Ease of installation:
Novice
Harness was so easy to install I didnt even have to refer to the well written and illustrated instructions included with the harness.
Harness and instructions. As received
Open hood, disconnect battery.
Remove headlamps and battery.
Harness pulled thru H/L bucket.
Relays and inline fuse installed
Harness installed in less than 45 minutes.
Headlamps noticeably brighter even in broad daylight.
Thanks again 390Nut. Im very happy with the harness and would recommend this upgrade for anyone who needs it.
Sharkdance
70 F250 2WD 360/C6
alvinator
re: Brighter Headlights - Even in broad daylight! (photo's)
Post by alvinator »
well I will sure be needing one but have to get my truck back together so I can get to that point. Hopefully 390Nut will still be making some in a couple of months. :thup:
spartman
Post by spartman »
Why did you remove the headlights?
Don't you just unplug them from the back?
dcbullet
Post by dcbullet »
I'm looking forward to installing mine too! Glad that it looks to be real easy. I'm waiting to get a set of the halogen headlamps from LMC.
Sharkdance
spartman wrote:Why did you remove the headlights?
Actually, its only the left hand H/L that needs to be removed. I just removed both of them cuz it seemed like a good time to apply some dielectric grease to both connections.
But unless your missing the upper valance panel, I dont see how you could get to the back of the bulb without removing it.
Sharkdance
70 F250 2WD 360/C6
spartman
Post by spartman »
I see.
68F250
Post by 68F250 »
That's a nice looking kit! Great job Paul! :thup: :thup:
Barry
Lazy Jake
Post by Lazy Jake »
I would like to echo Sharkdance's post. I got my harness from Paul and was immediatly impressed with the quality. I installed mine behind the battery box without having to remove it, it was a tight fit but, very do'able. AND, the headlights are fantastic. I put new halogen bulbs (from WalMart) in while I was at it and the difference is like night and... I won't say that.
Thanks Paul!
Dale
1946 Ford business coupe
1968 Ford F-250 Camper Special
adrianspeeder
Post by adrianspeeder »
Mandatory mod :thup:
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
mercman1953
Post by mercman1953 »
That harness really looks like a quality piece. Nice going 390nut! I have used similar harnesses from aftemarket companies and they have got nothing on this one. It is really a great upgrade that everyone should be doing to our trucks. Along that lines you can also upgrade the headlights for not much more than the cost of replacement by going to Autozone, O'reilly, Pep Boys and look at Sylvania silver lite or something like that series. I have used these at our shop and been really impressed.
1968 F250 longbed 2wd.
Late model 351w c6 trans.
1969 F100 Explorer
360 3spd manual
1967 Fairlane wagon
302 c4 trans
