Rats nest....
kid
Post by kid »
Do you have a Voltmeter or a Voltage light probe? I have two old Fords and my brakes lights did not work on one and was flaky on the other. The rivet that holds the hot side of the brake fuse clip was causing both trucks brake light problems. The hot side of that fuse is the clip nearest the drivers side of the truck.
