heater hose question
Would someone please tell me which heater hose goes where on the outlets on the firewall? I failed to note position when I took everything apart. Thanks, Larry
- jor
re: heater hose question
The outboard hose has the heater valve in it and routes to the intake. The inboard hose goes to the water pump.
jor
jor
jor, Thank you,blue oval guru. I marked all the control cables, got all the flapper doors resealed and back where they went only to discover I had not done the obvious. Larry
