"gluing" down new sound dampener
Roodaddy
Post by Roodaddy »
Hi folks,
Simple questions...I'm replacing carpet and sound dampener (from NPD) this weekend. The old dampener came up with little trouble due to the lack of adhesive. I assume this was factory as there was some tar-like substance around the edges.
What should I use to hold down the dampener?
What should I use to hold down the carpet to the dampener?
Thanks!
Cheers.
Bill
''72 F350 Crew Cab
'72 Galaxie 850 Camper
lightning_msd
re: "gluing" down new sound dampener
Post by lightning_msd »
i dont think that was tar, ive always used urethane, its black too, and takes 2 or 3 hours to dry, it comes in a tube like silicone
flyboy2610
Post by flyboy2610 »
Some spray adhesive from the local do it yourself lumber center should do it.
lifted72
Post by lifted72 »
i just put sound dampner in my pickup today. I used loctite spray adhesive. You should also invest in some aluminum tape, and VERY sharp scissors or razor, because it is extremely hard to cut through.
