LOOK (Warning large pics of F600 panel!!)
Before shot
After shot, atleast thats what it will look like. That has got to be the best lookin gauge cluster out there!!
Isn't there supposed to be a needle on your speedo gauge????
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: LOOK (Warning large pics!!)
Its invisible. It only shows up when i get excited!
That pic it is still in the f-600
- Ranchero50
- RebelRider
Those gauge clusters are cool!
- jor
Have any of you guys tried a chrome or other specialty powder coats on one of these? I'm thinking it would be a relatively easy job with good results. I'm just starting to do a little powder coating and maybe I'll redo the gauge that I painted a couple of years ago.
jor
jor
Would it look like real chrome ???? The powder coat??
- jor
I haven't yet tried the "chrome" powder coat but I have seen photos on the powder coating forum that I frequent (http://forum.eastwoodco.com/) and they look great. Most cover it with a coat of clear powder coat.Would it look like real chrome ???? The powder coat??
jor
interesting!!
re: LOOK (Warning large pics of F600 panel!!)
Powder coat Chrome finish looks more like a high polished aluminum. It is a real nice finish, but it is not as bright or reflective as real chrome.
Leo
Leo
Here is a picture of mine It is powder coated with a dark gray metallic called Heavy Steel
Leo
Leo
- 71PA_Highboy
I have a question on these panels.
It appears some of them have 2 switch plateaus on the left (one which usually appears to be wipers) and some that have 3 Switch plateaus on the left (see Tinmans photo above).
What are the year differences, and what could/should those switch plateaus be used for in a stock configuration?
Thanks!
Eric
Thanks!
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Can't tell you which year and which spec, but you could use them for manual choke pull, lights, blinkers, fog lights, etc...
I actually have a chrome/black version in my garage that I'll be selling soon. Has some surface rust on chrome and the oil pressure gauge was replaced with a mechanical one. Has the cable driven rpm/tach gauge, but no vacuum gauge.
I am at work and will post pictures later tonight when I get home.
Patrick
Patrick
Chevrolet
- 71 LONG BED
The black and chrome ones are from 73-79. The white ones are from 67-72. I believe the 73-79 version had 2 plateaus and the 67-72 had 3.
John Member #1549
