home made brake brakets
- customcrewcab
ok i didn't make them at home but at my buddys shop. i did all the machine work and design. he did the welding. not to shabby for my first ones. i'll get some more pics tomarrow of them bolted up on the spindle with the caliper mounted.
![Image](http://www.fordification.com/images/forum/ty.jpg)
- customcrewcab
re: home made brake brakets
ok i couldn't wait. heres some pic's of them mounted on the spindle. i will have to get some hardwhare to get the calipers mounted.
- marz68
- customcrewcab
more pics, ya 3/8" thick
- marz68
