My headlights are going to give me a seizure!
My headlights will start to flicker from time to time. It will begin to happen when i am driving on dirt roads mostly, but it won't stop until i turn the truck off over night. i have gone through and checked the wiring and it looks fine. this has only happened twice in the past year, but i dont think it is something to be taken "lightly"
- Heavenlyfire
re: My headlights are going to give me a seizure!
Sounds like the plugs on the back of the lights themselves might be getting loose or even corroded. I would pull them off and see if they are corroded and at the same time you will be able to tell if they are fitting loose.
i forgot to mention that they are blinking at the same time
If they are doing it at the same time with both lights I would think it is a loose fuse or a bad ground. Check them and maybe even add a new ground. But if you have a good harness I would check and clean all your grounds
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
- heep70
Headlight switch is bad.
Well known issue with them. It is a safety feature.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 71 LONG BED
Mine are doing the same thing. I remember there was a topic on this not to long ago. I think it was supermike that was asking about a new switch. He got a new one at an auto parts store for around $20-$30. The restoration catalogs get almost $100!! I did a quick search but couldn't find the thread. Maybe someone else has a better memory than I do and could put their in.
John Member #1549
- 71PA_Highboy
I assume you do mean BLINKING, rather than Dimming and brightening.
If it is Blinking, it is most likely the headlight switch.... it can be a bad ground behind the passenger headlight too...
If it is dimming and brightening, it is the points style voltage regulator... Get an electronic voltage regulator if this is the case.
Good luck!
Eric
Good luck!
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 71 LONG BED
Oops, my memory doesn't serve me like it used to. Thanks for clearing it up Mike.
John Member #1549
I'm having the same problem...mine did that yesterday and now the won't come on at all nor will my brake lights...
i replaced my headlight switch and it fixed the problem! it also fixed the problem with my lights in my guage cluster. now i can actually see inside my cab when is dark! Thanks!
I was thinking that a bad connection on the ol dimmer switch might do that, a friend of mine had a similar problem with his dodge
68 f250 "highboy" frame
67 np435 trans
68 dana 24 t case
67 dana 60 rear w/track loc
76 dana 44.6cf front w/DPC and heavy duty hubs
70 ford body w/rust incuded!!!
R.I.P. the 87 subaru GL wagon "the traildancer"
67 np435 trans
68 dana 24 t case
- Supermike
Re: re: My headlights are going to give me a seizure!
Johnm wrote:i replaced my headlight switch and it fixed the problem! it also fixed the problem with my lights in my guage cluster. now i can actually see inside my cab when is dark! Thanks!
Kragen's lists this part number for their headlight switches. They are also known as: Murray's, Checkers, Shucks, or Kragen's of course. You can also order from their website www.partsamerica.com Also this is listed for a 68 F100. I imagine it would work for the rest as well.
Niehoff Ignition Headlight Switch: Formerly FF147X
Part Number: HL16721 $13.99
Niehoff Ignition Dimmer Switch Floor Mounted
Part Number:DS29071 $3.69
1968 Ford F100 2WD 360
Ford 1 & 2 BBL and Carter 1 & 2 BBL Carb Rebuilder Extraordinare!
