Reverse lights not shutting off
theogre5150
Post by theogre5150 »
My reverse lights do not turn off for some reason except for when I shut the truck off. The only thing I have done is replace the flasher for the turn signal. Do I have a short somewhere?
kaptnkaos
re: Reverse lights not shutting off
Post by kaptnkaos »
Hey Eric
Check the switch on the brake pedal bracket...
I't may have gotten stuck or shifted just enough that it doesn't break contact when the pedal returns. I've had that happen before...
take care,
KaptnKAOS
flyboy2610
Re: re: Reverse lights not shutting off
Post by flyboy2610 »
kaptnkaos wrote:Hey Eric
take care,
KaptnKAOS
I think you should check your reverse switch.
kaptnkaos
Post by kaptnkaos »
Oops ... my bad, I mis-read the question...
yep... probably won't fix the backup lights by checkin' the brake switch...
Sorry about that... I had a problem with my brake lights staying on and they would drain my battery dead.
Hope ya figure it out.
KaptnKAOS
TRMMULLET
Post by TRMMULLET »
do they stay on through all the gears?
68 f250 "highboy" frame
67 np435 trans
68 dana 24 t case
67 dana 60 rear w/track loc
76 dana 44.6cf front w/DPC and heavy duty hubs
70 ford body w/rust incuded!!!
R.I.P. the 87 subaru GL wagon "the traildancer"
NXD 5150
Post by NXD 5150 »
Quick question, wheres the reverse switch located at?
theogre5150
My reverse switch was stuck. Cleaned it up the contacts with some electronic cleaner but am having a horrible time trying to reinstall it. NXD 5150, I will post a pic of where it's located.
for an auto the switch is on the bottom of the column inside the cab near the firewall. if it a manual it could be in two places on the column inside the engine compartment near the firewall or on the trans if its a np435.
theogre5150
What is the best stuff to use to lubricate the push button? It seems to be having a tough time trying to pop out.
kaptnkaos
Post by kaptnkaos »
Hey theogre...
If it is hanging up while out of the rig... I'd just replace the switch.
Why go thru all the hassle of putting back in a problematic switch?
It will give you problems again soon if you just try to lube it.
my thoughts on problem solving...
Do it right or do it again...
I learned that from a very hard headed Irishman
KaptnKAOS
theogre5150
Ended up cleaning off the contacts with electronic cleaner and I greased the button with some white lithium grease. After I pushed it in a couple of times it started to work. Thanks for all of the replies on this.
Kiamors
Post by Kiamors »
Those reverse switches are quite a problem, The most common solution I have seen on these old trucks is just to mount a toggle switch under the dash or in the case of my truck, where the broken emergency brake light was. Kinda redneck, but I mean, it is an old truck. Besides, if it was good enough for my dad, its good enough for me.
