73-79 dash conversion ?
tybob81
re: 73-79 dash conversion ?
Post by tybob81 »
If you open the holes out a little you should be able to put autometer gauges in. When I had my round cluster I did not have the means of a tool or mill to open up the holes were they would look good. So I sold it to a guy wanting to use the factory round gauges and used that money to but my billet insert. If there is a will there is a way, so figure out a way to mount them and you'll be set.
wt4speed#2
Post by wt4speed#2 »
Hey fitz
I got one in the garage , F-600 gauge panel ,that is. You should come by and check it out.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
fitzwell
Post by fitzwell »
wt4speed#2 wrote:Hey fitz
done.....you gonna be around tonight?
wt4speed#2
yea
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
