Reverse Lights
- 1970FordTK
Reverse Lights
I have a 1970 f-100 ranger with a 360 v8 C-6 automatic, one where is the reverse switch. Cause I can't get power to the lights in back, and I'm to stupid to read wiring diagrams.
- 68F250
re: Reverse Lights
It's near the end of the column by the firewall, a combination reverse light/neutral safety switch.
You could also be missing the factory jumper on the other side of the firewall.
Barry
- 1970FordTK
re: Reverse Lights
Got that switch, it works well for the netural safety and in park deal. What is the jumper for the other side of the firewall look like?
- 68F250
re: Reverse Lights
I don't have a pic, will try to take one tomorrow. There's a connector near the column by the firewall in the engine compartment that has a jumper wire bypassing it. That connector is used for a different reverse switch when you have a three-on-the-tree. The wire colors are black/red stripe.
Barry
- 1970FordTK
re: Reverse Lights
Roger that, thanks. I'll look it over, thanks in advance for getting the picture. Having a picture to see what to look for helps me in ways I can't describe.
- 1970FordTK
re: Reverse Lights
Took a "working" lunch to check on the jumper wire, that was the problem. Looks like a squirrel used it to pick his teeth with. Thanks.
- 68F250
re: Reverse Lights
Super!
Glad you found it. Sorry I worked late and didn't get a chance at a pic.
Damn squirrels.
Damn squirrels.
Barry
- 1970FordTK
re: Reverse Lights
Hey, I got faster info here than I would anywhere else on the planet.
