what is a "field relay" ?
ima71 trucks are older
Post by ima71 trucks are older »
I need to replace the charging harness on my 1969 F100 (it's completly fried)
The wiring diagrams on this site show a field relay in the system. This diagram for normal 1965-up alternator shows no such relay. will a charging system wired like this work?
I'll be using a new stock alternator and a new voltage regulatior
68F250
re: what is a "field relay" ?
Post by 68F250 »
The field relay is inside a normal alternator regulator, you don't see it.
The high-output alternator/regulator breaks out the field relay into a separate component. Look at another wiring diagram for the charging system, not the 65 Amp diagram.
Barry
thanks, I got it wired up.
