Dome light not working
71 LONG BED
Post by 71 LONG BED »
ToughOldFord wrote:
71 LONG BED wrote: That's a good thought but it actually works as long as the light switch is in the driving lights only postion. :dk:
That tells you it's drawing it's power from the parking lights. Somehow...
Exactly! But there are no spliced wires that I can see. It looks like the wire goes directly into the plug as it should. :?
rjewkes wrote:is the light working with the lights o with you opening the door to activate or does it come on when you turn the knob all the way to the left?
It works just as it should when the doors are opened,...as long as the light switch is in the driving lights on position. I'll have to look into the door switches to eliminate the possibility that they could be bad, and see if I can narrow this down to the exact problem. Thanks for all the ideas so far. :thup:
John Member #1549
Image Image Image
Thunderfoot
re: Dome light not working
Post by Thunderfoot »
Hey John,
Been looking at this all day and I modified a drawing for you here that has the wires and where they go... You can check these out with a test light.
Note: that there are two connections that aren't used but one of them only has power when the switch is in the "running lights" aka "park lights" position... wonder if someone wired the power wire for the dome light to it???
Hope this helps...
Let us know what you find out.
