Turn signal problem solved
The_Eman
re: Turn signal problem solved
Post by The_Eman »
My gas guage works very accurately. Over the weekend I will post a video of it on you tube. and post the link. I don't think it is a power drain issue. I'd like to discuss more after those are interested watch the video.
The ammeter doesn't move under any other load conditions.
kid
Post by kid »
Go on the back of the old Dash and move the wires from left to right and the gauge will work backwards. :lol:
i think its a crossed wire some place or something. that is weird. i will put some gas in my 68 and check mine out this weekend to see if mine does the same.
The_Eman
Post by The_Eman »
Well I'm at a loss. I replaced the loud relay with something closer to a stock one. Still the same problem.
kid
Post by kid »
That is not a Problem. I told you not to buy parts for normal operations.
be right back i'm going to put a battery in it. i'll check it out.
my ammeter does not even move with the headlights turn signal and domelight on all at the same time. does your dash blinker light come on when the turn signals are on. maybe the ammeter and turn siganl piolt light is switched around.
The_Eman
Post by The_Eman »
Yes the blinker light does come on. The reason I'm being stubborn to "Kid's" suggestion is because the ammeter moves like second hand on a watch. tick tick tick. back and forth back and forth. I don't believe that indicative of a power drain.
The_Eman
Post by The_Eman »
And... the second relay only cost me $2.36 with tax. I can sell it on ebay for three times that plus shipping. :lol:
Thanks for taking the time guys.
Thunderfoot
Post by Thunderfoot »
I've been looking at the wire diagrams and there are MAJOR differance in the wire harness between if it has the idiot lights or full gauges... But there is a common terminal that is used for one or the other... I wonder if someone wired them together?
Here is what I'm referring too...
On this diagram for full gauges look at wires 654 and 655 for the amp meter http://www.fordification.com/images/sch ... gauges.jpg note the location of the “neutralâ€Â
The_Eman
Post by The_Eman »
Hmmmmmmmmmm.
I'll am going to look at this very closely. I was thinking about this last night and I don't think my ammeter is working at all. The needle is basically stationary in the middle of the guage whether the truck is on or off.
i have thought about this too. it seems to me that there is a feedback going on some place. the blinker is feeding back through the ammeter circut some how.
The_Eman
Post by The_Eman »
Where does the ammeter rest when the truck is off? Or where should is rest?
in the center.
The_Eman
Post by The_Eman »
I need some more help. The flasher and the ammeter are wired into the same terminal which I believe is causing my problem but I don't know where or which terminal the blue wire for the flasher is supposed to be wired. Thunderfoot (thank you btw), you pointed to a 70 F350 diagram and I don't think that is the same for the 68 f100 and I can't find a diagram for the 68/69 that shows the wiring for the flasher. Here are some pics. I'd really love to solve this one.
