460 swap starter questions?
- 68swb
Ok i bought a new starter today and it is the one with the solenoid on it. The motor is a 429 manual 3 speed in a 68 f100. I need to know what wires i need to hook up to the starter and what to the solenoid on the inner fender which is now the relay. there are 4 post on the starter 2 small ones and 2 larger ones. i know that one larger one has the hot wire from the (relay) nothing goes on the other large one. and the 2 small ones, one is marked with a "R" and the other is blank with no markings. on the (relay) it is the typical 4 post relay on is marked "s" and the other is "i". so what do i need to hook up to what? sorry for the long post just want to get everything out there for your guys help.
"I got this"
68 swb 429ci 3spd
69 lwb f250 360 4spd
75 VW superbeetle
79 F250 4X4 supercab 400 4spd
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
re: 460 swap starter questions?
Check this out it should show you how to hook it up... http://www.fordification.com/forum/view ... 328#212328
- 68swb
i will give that a try and see if it works. the relay i have is a 4 terminal do i need to get the one that is just a 3 terminal type?
"I got this"
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
If your taking about the relay (starter solenoid) on the fender well, NO... the 2 small terminals, one goes to the ignition to activate the starter and the other goes to the coil for extra voltage for start up... If your taking about the one on the new starter itself, I think it should still work just have to try hooking to one or the other and see which one activates the starter. (I would try the one marked (R) first...
If you can get us a picture of the starter and the terminals on it that would be great as I haven't seen one with 4 posts on it before... also year/application it was for...
Let us know how it goes.
- 68swb
The starter i bought is for a 74' f250 460 2wd. i will try everything that you have suggested when i go back to the shop to work on the truck.
"I got this"
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
got it... I looked up the solenoid at parts america and found this http://www.partsamerica.com/ProductList ... r+Solenoid
It says: "Disregard R Terminal For Hi-Temp" not sure what they got going on there but sounds like you would not use this terminal...
So, I would hook it up like that diagram I linked to you before, and use the small one that is not labeled for the activation (start) wire that goes up to the fender solenoid...
See what happens...
Sorry not better help... the ones I have been using are off the later 93 models... but I think it should still work pretty much the same
See what happens...
- 68swb
I got it all hooked up and it works great. I even hooked up the ignition system, so now i can spin over the motor with the key and also have spark. thanks for your help.. That is the reason this site is great.
"I got this"
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
Glad to help and that it all worked out and your getting it going
If your talking about the larger ones = old ones like we have on our old trucks:fordman wrote:what if i wanted to change my mini starter back to larger one on a newer truck would need a different solinoid? or could i just reroute the wires?
You would have to mount a solenoid on the fender like we have on our old trucks to handle the load that the starter uses from the battery, and wire to it... These new mini starters have the solenoid built into them...
If a guy want to clean up the wiring on going to the mini starter on our old trucks and you didn't need the "start voltage" wire for the ignition coil, you could just wire a 30amp relay to the mini starter for activation, and the main battery cable for power of course
If your talking about the larger newer style starters that have the solenoid on them compared to the small mini starters... no need to change any of the wiring...
