reverse light switch on transmission.
- 1971ford
re: reverse light switch on transmission.
it was very dark so the pictures are very bad but it may give you an idea. i dont know.
end of the steering column:
i dont know if this plug has anything to do with my problem but this plug is sitting on my inner fender.
here is a pic of it in its natural habitat .
-Ryan
- 1971ford
are you talking about the washer still or did you switch back to the lights. and if your talking about the washer, are you describing what the plug looks like that i need to plug the one in the pics into?fordman wrote: look up higher towards the cab for the black crossed over wired plug.
it looks like a plug with a short little wire going back to the plug itself.
-Ryan
- 1971ford
- 1971ford
- 1971ford
the wires come out of that switch and go up and through the firewall to the engine compartment to a plug that routes the circut back to itself. and copletes the circut. if the plug is in place then test it at that plug if it good at the plug then follow the wires back to the rear of the truck to see if you still have power back there. if there is no plug then make a plug to complete the circut. or if its not not at that plug then the problem lies under the dash after the nss and before that plug.
