Heater blower not blowing
Well, got in the truck after work today and turned on the heat. Haven't had a problem until today. It's getting kinda cold here so I turned on the fan to high. Nothing blowing out. I have heat but it seems that the blower is not working. I checked the fuse and it is not burnt. Has my blower gone out or is there something else I can check?
re: Heater blower not blowing
Eric, that is odd, did I read your reply backwards or did you type it backwards? Is the required fuse value 20 amp and it had 30 amp in there and blower wouldn't run? That doesn't make sense. I could see if required value of fuse was 30 and it had 20 amp and kept blowing? Sounds odd.
- seattle67
Most likely the contacts on the fuse were dirty and made a better connection again when he put the new fuse in.
![Image](http://i224.photobucket.com/albums/dd33/zortot/DSCN1258-2.jpg)
ogre, it is good you did, because if it has a short somewhere, that is an old trick to keep something working (despite short) keep upping the amps till it doesn't blow. I've even bought old cars that folks have taken a fuze apart and used a paper clip bent up inside it to make hard contact so it couldn't blow. I've also known of a guy used a bolt in a fuse holder to "go ahead and find his short" in other words to watch a wire smoke. Good way to burn a truck to the ground and possibly the home it's near (both tricks). You're probably right about corrosion.
I have gotten alot of non-functional electronics working by electrical contact cleaner and wiggling back and forth and sometimes even without the cleaner. Headlight switches, wipers, radio's (tuner knobs), etc. it was probably just the removal and replacement that helped more than any. I'm still gonna call you sometime to go junkyarding have just been too busy. Just got in from Smoky Mtn, Banjo.
ive seen a stick with foil wrapped around it for a fuse
the problem i had with mine was the main hot wire corroded off i pulled the box and wired all my stuff with inline fuses labeled ofcouse a good poor boys fix ![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
Hey, that kinda sounds like what I found on my 4x4 after I hauled it home....some SERIOUS red-neckin' going on here!
![Image](http://www.fordification.com/board/fusebox01.jpg)
...and I'm sure that's what caused this:
![Image](http://www.fordification.com/board/fusebox02.jpg)
SHEESH!!!![Confused :?](./images/smilies/icon_confused.gif)
![Surprised :eek:](./images/smilies/icon_eek.gif)
SHEESH!!!
- basketcase0302
Keith,
Now what's the matter with that?
Redneck 101 thinkin'
The tensile strength of the non-hardened grade 5 nut +
The NC thread count of like 18TPI+
The 5/16" nut size=
A 20 amp brake circuit fuse!
Basketcase
The 5/16" nut size=
Basketcase
- seattle67
How come I cant get "dueling banjos" from deliverance out of my head.
