Smokin' starter!
nikon4u
Smokin' starter!
Post by nikon4u »
I keep burning up my starter with my headers being as close as they are to it. What have you guys used to solve this? If the answer is a mini high-torque starter, then which one exactly. Should you wrap the headers, I have heard that will cause them to rust out quickly. I have seen starter wraps, but I wonder if that will cut off airflow to it, so is it better to wrap it or to leave it so it can get some air to cool it. I need some response soon because my starter is making some odd noises and I need to get a solution today :help:
I just got my web site up! Check it out!
http://www.Handyman-for-rent.com
"If it ain't broke, don't lend it"
--Red Green
http://www.fordification.com/galleries/ ... ?cat=10491
Fake Name
Post by Fake Name »
I'm using the Powermaster starter and I had my headers jet-hot ceramic coated inside and out. Bring your wallet. Here's the link:
http://www.powermastermotorsports.com/2 ... rters.html
$217 at Jegs
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
nikon4u
Post by nikon4u »
Which one did you have? I found this one at jegs.
http://www.jegs.com/webapp/wcs/stores/s ... 2_75380_-1
--Red Green
Fake Name
Post by Fake Name »
That link won't work, but it's a 9506 (I believe). Look at the Powermaster site to determine your application. I bought mine from a member here who had gone a different direction.
I'm assuming you have an FE..
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
nikon4u
Post by nikon4u »
--Red Green
nikon4u
Post by nikon4u »
Yeah, FE
--Red Green
nikon4u
Post by nikon4u »
Yeah, FE
--Red Green
nikon4u
Post by nikon4u »
Try that Jegs one now.
--Red Green
Fake Name
Post by Fake Name »
I don't know anything about the Jegs brand. My exhaust guy, who's seen these hundreds of times, said I bought the "right" starter, meaning the Powermaster. But the jegs might be just fine. I just HATE the idea of doing anything twice (well, just about anything) especially a starter change.
I also replaced all my primary wiring with 2/0 wire with soldered connections. Not #2, 2/0. It reduces strain on the electrical system, and delivers the power when/where it's needed, especially for a heat-soaked starter.
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
nikon4u
Post by nikon4u »
Not sure I know what the difference is in the 2 wires.
--Red Green
Fake Name
Post by Fake Name »
Different gauges- 00 or 2/0 has a diameter of .3648 in and #2 is .2576. Or, more simply, 2/0 is bigger and fatter. And a lot more expensive. But when dealing with big-amp DC, size matters.
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
mrsnicks
Post by mrsnicks »
You could always fab up a metal/aluminum heat shield between the headers and the starter if you have room. Just something to absorb, deflect the heat coming off the headers.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
nikon4u
Post by nikon4u »
Thanks Patrick, but that's what I did with the old one, and it kept air from going around it.
--Red Green
if you can get a mini starter that would be the best way to go and keep the headers. the only other way i can see to go is to get rid of the headers.
nikon4u
Post by nikon4u »
I bought the one from Summit. It will get here next week...I hope my current starter will last!
--Red Green
