Fuel Sending Unit
green68250
Fuel Sending Unit
Post by green68250 »
Hey,
I just replaced my fuel sending unit after verifying that it was the unit and not the guage. Now the guage only says half full when the tank is full and I can hear the float hitting the side of the tank. It never hit before and I don't know what the problem would be. How would I tell if it is a falty unit? Any ideas as to what it could be.
Thanks a lot!!
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
the float hitting the tank is a result of no rubber piece on the float . i'm guessing. you will probably need to readjust you ivpr or whatever its called on the back of the inst cluster. that is because it is a different unit you put in. so the voltages may be diffeent from one sending unit to the next this is just a guess though.
green68250
re: Fuel Sending Unit
Where is this rubber piece that is supposed to be on there? How do I adjust the instrument cluster?
Thanks again,
Corbin
here you go. it has some pics of the rubber cover and info on the adjustments.
http://www.fordification.com/fuel-sending-units.htm
green68250
Yeah I was just reading that. Any ideas where I could get a new rubber piece for the float? The funny thing is that my old unit didn' t have that peice in it either and it didn't rattle. I know the wiring from the guage to the unit is good because I grouded the power supply and the guage went to full. I will check to make shure the guage is reading the right ohms. If it is I am out of ideas.
Thanks for the help,
Corbin
i dont think i have one but i'll look. but surely they can be had from one of the aftermarket dealers on the links page.
green68250
Ok thanks fordman, I put my old one back in after I cleaned it up a little and it seems to work a little better but it still wont show full. The new one I got is useless when I hooked it up and moved the arm all the way to where it should show full it only showed half. I did the same with my old one and it will go to 3/4 but no higher. I dont know what would cause this. I guess I will just keep filling it up often untill I figure it out.
Thanks again for the help,
Corbin
69twotone
Post by 69twotone »
Green,
Have you tried the local u pull it. I was having the same problem and went to the u-pull it and bought one for $6.00 figured if it did not work six bucks is not a big loss.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
Here's a thread on adjusting the IPVR (instrument panel voltage regulator).
http://www.fordification.com/forum/viewtopic.php?t=9698
