Frigette is from Ft Worth and I belive they are still in bussiness. Several guys that I went to high school with worked there. I believe if you google them you'll find more. As for parts for that particular unit who kmows1971ford wrote:i dont want to hijack this thread, but is this anything special? behind it is the factory heater. i gues the PO added the ac compressor and linesit says "frigette" so probably an aftermarket heater/ac.
Ranger II air conditioning
- wt4speed#2
Re: Ranger II air conditioning
I will get photos, I have the exact same a/c, it does curve with the dash and I have all the correct mounting brackets (I also believe mine to be factory or installed by dealer). The idler pulley was lost somewhere.
I inherited this truck from my father about 2 years ago (currently 18 years old), and I am working on it. I have the paint code but figuring out if it was deluxe regular or combo is a bit of a challenge.
Mine is a 1971 f100, auto, p/s, p/b, 360, long bed w/ a tool box, plus a/c.
One last question, does anyone else have an am/fm 8 track radio in their truck?
