OT...1990 Ford Bronco doesn't go ding-ding.
My dad has a 1990 Ford Bronco that has a little problem that's driving him nuts. When you open the door and the keys are in the ingition, it's supposed to go ding-ding-ding. Well, his dinger has broke. Does anyone know if there is a relay somewhere that creates the ding?
Cooter
Cooter
- l1k2gadd
re: OT...1990 Ford Bronco doesn't go ding-ding.
With the key in the ignition BUT in the off position and the door open the door chime should work. When the unit starts to go bad the chime can and often gets re-e-e-eal weak. Sometimes you can hear the weak chime noise coming from the unit if you listen real close to the dash.
However, the chime should work when the headlights are left on in some vehicles and the door is opened (without the key in the ignition). See if the chime works when the headlights are left on and the door is opened.
If it does then the little brass strip on the ignition cylinder that makes the chime work with the key is left in the ignition might have gotten worn or bent and isn't making contact inside the column key switch.
- lightning_msd
thats weird, i dont have a ding ding in my 90 mind you my power locks dont work either
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
You also have to keep in mind that many folks find those very irritating, and will remove the 'dinger' or maybe snip a wire going to it. Silence is golden.
Re: re: OT...1990 Ford Bronco doesn't go ding-ding.
lightning_msd wrote:thats weird, i dont have a ding ding in my 90 mind you my power locks dont work either
you didnt play with it too much did you? they say that can make you go blind you know
- lightning_msd
i walked right into that onefordman wrote:lightning_msd wrote:thats weird, i dont have a ding ding in my 90 mind you my power locks dont work either
I checked with my dad and he said that with the headlights on and door open, it still does not go ding-ding. I assume this means the dinger itself is broken. Someone told me it was under the dash, by the glove box. Anyone know for sure? Remember..1990 Bronco.
Cooter
Cooter
- lightning_msd
go on FSB forums and do a search, if nothing shows up they will be able to tell ya
www.fullsizebronco.com/forum
- l1k2gadd
Yes and a lot of those key-in, headlight-on door chimes and buzzers are the same, vehicle to vehicle. Some ring, some chime and some have that irritating buzz.
I found that the '90 Mustang I have has the same chime as the 1993 era Ford Explorers. They are just mounted on different brackets.
