No Brake Lights - 1969 F250 Camper Special
thats either a bad flasher a bad bulb or it could be the switch. or maybe a bad ground. i don't remeber what that syptom is for sure. its one of those things.
Thunderfoot
re: No Brake Lights - 1969 F250 Camper Special
Post by Thunderfoot »
Check when you hit the brakes if the right front turn light comes on along with both the rear lights. If it does then that new switch is causing this problem also...
Supermike
Post by Supermike »
fordman wrote:thats either a bad flasher a bad bulb or it could be the switch. or maybe a bad ground. i don't remeber what that syptom is for sure. its one of those things.
Most likely a bad ground on the right side... if it were the flasher, then the left side would not flash. Could be the switch, but this is what happened to me when I had that trailer adapter installed... the blinkers would quit working when my brakes were pressed. Turned out the adapter was wired wrong and not grounding.
So... point being... you might check the ground on the side that's not working.
rjewkes
Post by rjewkes »
i had a dead wire after the underhood connection for the lights. so i had to jumper that connection.
but then i had no brake or turn on that corner.
