Started up the F100 after 12 yrs (movie) - Christmas update
My427stang
Post by My427stang »
Well, spent some money the past few days
- New set of Jet-hot coated Hedman headers
- New Black crinkle Lemans FE valve covers
- New Chrome Ford air cleaner with hipo 390 sticker (LOL)
- New 750 Vac sec Holley
This week I detailed under the hood and painted the long block (its only got 10K on it), replaced the rear main seal and painted the oil pan, and cleaned the aluminum intake
Tomorrow I am going to clean up the wiring harness and make things a little prettier than they were
I am out scouting for prices to get the bed walnut shell blasted and epoxy primed while I put the Dana 60 and new rear springs in
Coming along well, more pics in a week or so when the engine compartment is finished!
1971ford
Post by 1971ford »
sounds purty, but you forgot the pictures :(
:D
-Ryan
nadams
re: Started up the F100 after 12 yrs (movie) - Christmas upd
Post by nadams »
Ross,
I am glad you got it running again. :thup: Is that a 3 groove pulley you have in there? Thats the nicest one I have ever seen. :lol:
cghstrojan08
Post by cghstrojan08 »
1971ford wrote:sounds purty, but you forgot the pictures :(
:D
Ya, need some pics please.
ROBERT
Member #1076
1968 F100 SWB 360
My427stang
OK, some pics, more to come on the truck :)
Here is the new carb, 750 vac sec
Here is one of the new valve covers
And another view. Needless to say the carb will be swapped and I am going to get the distributor looking good :) I swapped the oil pressure sender and detailed the oil filter adapter just after this pic!
Jet Hot coated Hedman Headers are due here next week, I'll update with assembled and final detail underhood ASAP!
basketcase0302
Post by basketcase0302 »
Same carb I've got on my boat, (but I have the marine version with electric choke).
I love that carb with the center-hung floats, and ease of working on.
Like the valve covers too. :thup:
Basketcase
BobbyFord
Post by BobbyFord »
Prolly what happened to the pushrod was old gummed up gas varnish on the valve stem and guide caused the valve to hang up in the guide.
cghstrojan08
Lookin good.
ROBERT
Member #1076
1968 F100 SWB 360
Manny
Post by Manny »
My427stang wrote:One a custom on-of-a-kind corner-turnin pushrod
Hey i got two of them out of a 360 in a 75' amazing how the quiet down eh. Glad you got er going again always a triumph :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
My427stang
Getting there
A few more pics
Waiting on my headers, didnt show yesterday, a different dual feed line, and a backordered repop Ford hipo air cleaner complete with "High Performance 390" sticker
Current air cleaner is temporary, and very ugly needless to say LOL
Still need to detail the lower steering column mount, change around how the heater hoses run, and run the brake booster vacuum hose correctly on the original tie downs to the cowl
hotrod ford
Post by hotrod ford »
man thats a good lookin engine. that air cleaner is a monster. will the hood clear the height?
My427stang
I can go another 3 inches.
That filter used to be on the motor with a 1 inch nitrous plate, a Predator carb and a heat shield!
Matter of fact, years ago when I though it needed even more air I used to stack 2 of those filters with a drop down base
I am older and calmer now, just want a good running street truck, the Mustang is there when I really want to boogie
Nausea
Post by Nausea »
Looking great! Love the valve covers! :thup:
Was that spark wiring pre-made? If so, which it is it? Fits nice and I'm looking for a good set.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
My427stang
No I cut them to length 15 yrs ago, however I rerouted them and you can see #5 is a little long, I am going to shorten it. Might even be time to change them :)
I also had to open all the stock Ford looms with a dremel to fit the 8 mm wires
basketcase0302
Looks real nice! :thup:
15 yrs ago
And my wife thought I was the only one to keep old parts that long!
Ones on my bump now are bout' that old, (had to take laquer to clean them enough to be "presentable"). :lol:
Basketcase
