so my truck drives and stops.(latter is definitely a plus) I'm on to my next issue(s)
1: headlights and parking/tail lights all work
2: dome works- high beam indicator works
3: no turns inside or out light. instrument lights no work.
4: idiot lights light at start go off normally.(working properly i assume)
i replaced 1 flasher so far it was taped to my brakelight switch wire to keep from flopping around i guess.i gather from reading and diagrams this is my emergency flasher.
I am about to go poking wires from the headlight switch is the the first place to look? I would at least like to get the dash lights going since i drive home from work after dark and i can't see speedo. presently i'm using universal turn signals or left hand
oh and my brake lights didn't work either but i couldn't get switch back on when i installed new master and pushrod, what i mean is they didnt work prior to replacing master with switch installed.
one other thing i will try to take a photo, there is a big box under dash(relay) it is about 3x3 with 2 terminals offset. i will post a pic if i can take one and the numbers i can read, my head is a little big to get too far in there.
any help will be greatly appreciated.
David
