Wiper Motor or Wiper Switch?
- RWG
Howdy!
I have been trying to troubleshoot my wiper motor. I picked up a new motor but before I pull the dash totally apart I wanted to slide by and get some opinions.
The wires that went to the washer pump were disconnected so I fixed that problem and ended up with rust red sludge all over the windshield
Well I know that the washer function works but the wipers still wont fire up..
Just to make sure I covered all my bases I swapped the fuse with a new one and still no wipers.
OK so I start to trace wires and find that the Orange/white has 12 volt..
I checked the red,black,blue,white and none had any voltage what so ever.
So to try and isolate between switch and motor. I figure I would send some voltage down the red,white,blue... I assumed that black is my ground. I get a spark from the blue and the white and no motion to the motor..
I then assumed that the red is hot the black is ground the blue and white are my 2 speeds.
Nothing...
SO now I figure its time to slip in here and ask the gang...
And another question... ALL my inside and outside lights are surging with the lobe of the motor and get dim on a lower RPM and get brighter when the RPM is higher...
I assume that this is the sign of a weak altinator?
Nothing...
- l1k2gadd
The lights surging could be a bad alternator and / or a bad voltage regulator.
Did you buy a used wiper motor from another truck with the wiring connected to it?
- RWG
re: Wiper Motor or Wiper Switch?
I picked up a re-ferb motor from the Zone and yes the wires are connected with about 36" pig tale and are the same color code red,black,white,blue.
yes that is the way to test the switch to see if its bad is to connect the new motor to the old switch and turn it on. if it works then both the ols switch and the new motor are bad. if it doesnt work then one of them is bad. try tracing these wire on the diagram. this will tell you which wires do what.
http://www.fordification.com/images/sch ... washer.jpg
Just re-read this The Blue and White should have made the wipers move so I would say that you have both bad, the switch and the motor... The motor probably smoked the switch when it went out.
Or the wiper arms are stuck / froze so that the motor can't make them move.
Code: Select all
- RWG
Cool deal.... Thanks alot guys this helps allot..
Oh ya anyone have a spare wiper switch...LOL
- RWG
Should I run a ground to the body and attach it to the new motor in order to try and fire it up?
- RWG
Well well well!
Its the motor... I did as you guys said and lo and behold the new motor works great...
Man thanks a bunch guys the information I just got would have taken much more time if I had not become a member...
- RWG
Man,
Now I have to pull the dash apart.... But the cool thing is that this is the last thing I had to fix in order to get the safety inspection
A bit off topic but yesterday when I was replacing the plugs,wires,rotor and cap... I guess the old water pump felt a bit left out and asked for some attention by bleeding out some coolant!
So today I picked up a bunch of new stuff and ended up with a much quieter/smoother running motor...
A little rattle can work and she is coming along rather nice...
Let us know how it goes as I'm a little curious as to if the motor is really bad or arms attached to the motor are froze up... I have never pulled one apart but I think you have to pull the wiper motor out to get to them anyways...
Fordman is that correct or is there a way to disconnect them from the motor without pulling it?
i have always pulled the bracket out and took the arms at the same time. it seemed easier to do it that way to me. the arms ar held on by some wierd type of clips that aldie over the arm ends and then clip down over the pins. i'v never tried to remove those clips yet. i have two motor in the garage like that. with arms still attached.
- RWG
I will take pics as I pull it apart and stick it back together and post them here when im done... Might do a lil video just for the reality TV thing
