dash light fuse
worldsmysterie
dash light fuse
Post by worldsmysterie »
i have a 67 f100 and the wiring is all origanal i wanted to know which fuse goes to the dash lights or how do i go about finding it? thanks
4th effie n counting
re: dash light fuse
It is the littlest one in there. There being on firewall pretty much behind the light switch, it is a bugger to get out. I used a little screwdriver
l1k2gadd
Post by l1k2gadd »
You can try taking a short piece of stiff wire with the very end bent over on a 90* angle. Slip the wire into the fuse socket at one end, turn it to face the fuse end and slip it behind the fuse, and pull out on the end of the fuse. It might take a couple of tries, but the stiff wire should get the fuse to at least (edit) [pivot (oops, the other word was ****'d out)] to one side for easier removal.
