when i hit the brakes both turnsignal indicators light up
- kilog55
i assume this is the dummy light for the brake warning switch? if not how would i fix it? it has new brakes lines and a master cylinder.
also if ya can help when i put mu left turn signal on it puts my 4 ways on but my E flasher switch doesnt work
- wt4speed#2
the brake warning switch isnt in this problem. i think your porblem is the flasher cans. change both of them. unless someone has rewired the wiring in your truck. little more history on the truck mihgt help too. is this a new truck to you or have you had it for a long time? and has this problem just developed?
- kilog55
new truck to me havent really gone over the wires yet, ill have to look at the schematics
- ezernut9mm
i'd start under the bed in the rear of the truck. sounds like someone has cross wired the turn signals into the brakes. or it could be a bad ground. the turn signal cam in the column could also be toast.
- flyboy2610
That was my first thought.ezernut9mm wrote:the turn signal cam in the column could also be toast.
re: when i hit the brakes both turnsignal indicators light u
Sounds to me that your 4 way switch is on and the 4 way flasher is burned out. The fact that your indicater lights show while braking means that your front turn lights are coming on along with the rears indicating that your 4 way switch is turned on. Could also be no juice to the 4 way circuit(bad flasher or fuse).
Fred
Fred
- kilog55
yeah when i turn the 4 ways on nothing happens no flasher sound, when i turn my left turn signal on all 4 light up like if i had my flashers on. but when the right turn signal is on its only the right
- kilog55
yeah ill have to break out the arctic gear cause it's cold out there today. and i have no garage
- rjewkes
I also wonder about the condition of your wiring underneath the cab/truck and just aunder thdash or even up under the hood on the driverside inner fender.
BtW love the Avatar is that the boondock saints?
- kilog55
yeah it is. i know i have to look at everything really good cause this truck is old and it is all original cept the bed its from a 73-79
- kilog55
not sure really i gotta clean the bark and snow out of it cause i was wondering the same thing since the 67-72's are narrower. but i have a line on a really good 72 bed and parts truck to replace this one
- ezernut9mm
