removing some interior parts help...
1971ford
Post by 1971ford »
1) how do you remove the parking brake cable from the pedal assembly?Image
2)how do you remove the cargo light switch assembly?
thanks
-Ryan
you have to pull that key. you will have to work it around to the open side to get it out. those are fun.
1971ford
Post by 1971ford »
i dont understand :hmm:
ive gotten the cable ball out of the pedal, now i need to get the cable off of what it is attached to in the pic...
-Ryan
Ranchero50
Post by Ranchero50 »
There's a cotter key retaining the sheath through the housing plate. Bend a 16 penny nail and grab the nail with some vise grips, put the nail hook over the C part of the cotter key and pull till ya fart...
It'll come off. Other styles have locking finger that you need to use a 1/2" closed end wrench to slide ofer the fingers to release them.
Jamie
re: removing some interior parts help...
That's the clip that must be removed. It's shaped like the (crude) illustration in the lower-right corner. Pull that clip, and the cable will pop out.
1971ford
Post by 1971ford »
ok, ill work at it some more. thats what i was trying to do before i posted this thread. its hard.
-Ryan
You can put a flat piece of steel against the ends of that clip and then give it a whack with a hammer. It should pop right off, or at least enough where you can grab it with a pair of pliers or ViseGrips.
1971ford
Post by 1971ford »
thanks keith, ill do that :thup:
anyone know about the cargo light switch removal?
-Ryan
AlleyCat
Post by AlleyCat »
1971ford wrote:thanks keith, ill do that :thup:
Unscrew the knob then remove the nut that holds the switch to the dash.
Clay
1971ford
Post by 1971ford »
i still cant get the cargo light out.. but i got the cable out after 30mins :D
here is the easiest way i found:
i held one end of the pin with ViseGrips, and i pulled on the other like in the picture.
i wish i found this way when i started.
heres a shot of the pin:
-Ryan
ha i must be doing it the hard way then. because that looked to easy. i was dumb and tried to spin my pin around so i could just pull it out. i never thoought about just spreading the pin and pulling the cable out.
AlleyCat
Post by AlleyCat »
I spin the pin/clip around and remover it with a cotter pin puller.
Clay
Supermike
Post by Supermike »
This thread was VERY helpful to me last night in replacing my parking brake assembly! I tried doing it as pictured (spreading the pin), and that helped some but I just couldn't get it that way. Even with the grips, I could not pry it far enough apart. I finally rotated it around to where the "loop" (round) side is, slid in a screwdriver and pryed at it. Going that route, it slid right off and then shot across the cab. lol
To get it back on, I just put the round end into some needle nose vise grips and slid it on 1/2 way, then popped it the rest of the way with a tack hammer.
I thought the hardest part was getting the ball out of the clasp that holds it. Used a combo of screwdriver and pry bar tool to get that out.
:fr:
390Nut
Post by 390Nut »
Oh, that clip is REAL easy to remove. Just wait till you try to set the parking brake one day, and it will fly out and hit you in the leg. In two pieces. :(
It's almost as much fun taking them out as it is putting a replacement in. :lol:
Paul
`69 F100 390 4spd driver
