Today I tested my alternator and at idle it charges at 14 volts
but when I rev the engine it goes up over 17 almost 18 volts
I'm pretty sure if I run it like that the battery will boil, so after looking around a bit I noticed that
one wire went nowhere from the voltage regulator, I took some pics and this is as clear as it gets
there are 2 yellow wires and one is not connected, is it supposed to be?
I was thinking it was the sensing wire maybe?
Or is the reg hooped?
Thanks for looking guys
Voltage Reg wires
re: Voltage Reg wires
Thanks fordman, I wonder what the extra wire is for?
Maybe I should convert it to a newer internal reg set up.
- SteveC
that wire goes to what looks like a condenser
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Just curious steve, what is your voltage at now with wire hooked up to the condenser?
67 F100 240 I6 3spd now gone
- SteveC
dunno my only voltmeter is on the frits and how would i check it if i got it to work?
i know that my fuel tank only reads 3/4 full when its topped off and my coolent sender doesnt work barley
Dunno but that thing looks original its just as dirty as the rest of the under hood area.
Would this thing be causing a problem of some sort??
1967 f-100 4x4
1967 f-100 4x4
That is condensor/capacitor is only used for noise supression. That way you don't hear a whine through your radio when you accelerate. If your alternator is over charging and everything looks to be hooked up, than I would volt drop all of the wires to check for too much resistance and if that checked out good than just get a new voltage regulator.
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
