Hotwire how-to needed
FLATBEDFORD
Post by FLATBEDFORD »
I wil be picking up a parts truck ina week or so. It has no keys. The owner says that it was runing a year or so ago. I'm thinking that it would be easier to drive it on the trailer than winch it. I have a battery I can bring with me. What would I have to do to try to start it without a key?
My Photo Gallery
truckguy
re: Hotwire how-to needed
Post by truckguy »
The easy way is to jump the the starter solenoid. Take it out of gear first.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
FLATBEDFORD
Don't I have to get the ignition to the "run" position?
My Photo Gallery
truckguy
Post by truckguy »
Put power to the power side of the coil.
Kyle
Image ImageImage
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
FLATBEDFORD
That easy?
My Photo Gallery
truckguy
Post by truckguy »
Make up a jumper wire run it from the pos side of the battery to the pos side of the coil and jump the solenoid.
Or
If you have another switch you could use that.
Or
Put the wires out of the back of the switch and find which ones that you could jump to get it to trun over and have power going to the coil.
Kyle
Image ImageImage
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
for just loading i would just swap out your switch with the other switch.
19674x4
Post by 19674x4 »
easiest to jump it. run a jumper wire from the battery to the positive side of coil and jump the starter solenoid
My Photo Album
wildcard
Post by wildcard »
Seems you came to the right place to learn how to hot-wire a vehicle. :lol: Actually I done mine a while back with the batt. to coil route when I lost my keys. But if it's yours and you're going to have to change it anyway, why not go ahead and change it first. Then you can drive it on and off without raising the hood. Just my :2cents:
FLATBEDFORD
This truck is gonna be junked. I'm not gonna take the time to put a new switch in it.
My Photo Gallery
wildcard
Post by wildcard »
Gotcha. :thup: Then the jumper will be easiest and quickest.
1971ford
Post by 1971ford »
just wondering,
cant you get your switch or some junk switch that at least works, then unplug the parts trucks switch (if you can) or splice your switch in (presuming you had the key for it) ?
-Ryan
390Nut
Post by 390Nut »
:yt:
You dont have to install the switch, just unplug the one in the dash, and plug yours in long enough to make it work. It can dangle all over the place and will work just fine, and it's easy enough to remove afterwards. :)
Paul
`69 F100 390 4spd driver
4th effie n counting
if i'd read i 'd be better off... :doh:
this thread kind of bothers me. i dont think we should talk about how to hot wire our trucks in the open like this. i know most thieves will probably already know how to do this but wouldn't it be better to keep this in a pm situation. or maybe make this subject a registered user onyl thing? just like the wing window. just an idea.
