When the headlights are on I have no brake lights or turn signals at the rear. with the lights off I do. how should I trouble shoot this?
Thanks!
tail lights acting up
- l1k2gadd
re: tail lights acting up
Check your fuse panel. You MIGHT have a stop light fuse blown.
Do all your front and rear marker lights work? If one of them doesn't replace it, the element could have broken inside and shorted over to the turn/brake circuit which will could cause this.
If all the lights are good then check ground connections as bluef250 stated...![2 cents :2cents:](./images/smilies/icon_2cents.gif)
turkeydinner, you check your brakelight switch, fuse?
67 F100 240 I6 3spd now gone ![Sad :(](./images/smilies/icon_sad.gif)
