I hooked up the PS steering column and had some pretty crazy things happen.
When I turned the switch one way, I had nothing in the front, but both rear light blinked.
When I turned the switch to the other direction, the horn relay would click every time the light should...
I'm no electrician, but did come to the conclusion that somethin' aint right.
Now, I have a few questions...
Is there a way to test a turn signal switch ???
Anyone know how the power gets to the switch itself???
Wouldn't one of the wires on the column plug have to feed the switch which inturn would feed each circuit... right???
I bought the CS from the original owner who really didn't change anything except tp upgrade the engine from a 360 to a 390...
I have no idea if the donor truck had any alterations.. I do know that all the lights worked as they should when I dismantled it...
I'm, pretty sure I hooked everything up right...
But I was also sure that I had the plug wires on right, only to find out I was one hole off...
Any ideas woud be greatly appreciated...
Thanks in advance...
KaptnKA
