what is this wire for??
SteveC
Post by SteveC »
OK i believe this wire may go for the spare gas tank wiring but not sure when i hooked up the test light it flashes like all the sending wires. This is located on the drivers side inner fender near cab.
http://s169.photobucket.com/albums/u223 ... 010082.jpg
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
washer pump? maybe orits a fuseable link that can have a acsory wired into it.
SteveC
re: what is this wire for??
Post by SteveC »
not the washer pump it is different. im not sure but hmmm it only flashes with the switch on..ill have to read into it... i just thought maybe it was for the extra fuel tank sender cause its the same color as the incab tank wire
1967 f-100 4x4
SteveC
Post by SteveC »
Ok i found out that the wire is for the spare under bed tank sender unit. I unhooked the in cab tank wire and probed the wire and grounded it with the test light and as it was flashing with the switch on i looked at the fuel gauge and saw it was going up it only got to half way so i probally need to clean inside of the connector.
Several people may have know that but its news to me so i learned something new today :lol: :lol:
1967 f-100 4x4
ok i didnt know the 67 harness could have that wire for a sender to a midship tank. thats good to know. i will have to check my new 67 harness to see if it has that wire in it.
SteveC
Post by SteveC »
when i get time tomorrow ill see were it connects under the dash and get a picture it is going in with the wires near inner fender
1967 f-100 4x4
l1k2gadd
Post by l1k2gadd »
I just looked under the hood of the '68 F100 donor truck that I have here that has the belly tank under it. That same orange colored wire's female plug is connected to a harness that travels down under the truck along with the bed wiring harness. I believe it is for the belly tank's fuel sender, without tracing it out. Ford doesn't usuallt duplicate wire colors in a wiring harness for two different components.
The '68 F100 I drive every day, that doesn't have the belly tank, has the same orange wire with the female connector, only it has nothing plugged into it.
SteveC
Post by SteveC »
tracing it out on this http://www.fordification.com/images/sch ... uxtank.jpg i found a switch and the wires that go to the switch gonna still have to fabricate some but o well
1967 f-100 4x4
