Fun with chemistry! (Electrolysis)
71Ford100
re: Fun with chemistry! (Electrolysis)
Post by 71Ford100 »
See if you can get some heavier copper or aluminum wire and try that as a conductor.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
69F110
Post by 69F110 »
That is interesting stuff there. I never thought of doing that.
Sweet.
Steve Davis
Pastor and U.S. Army Retired
390Nut
Re: re: Fun with chemistry! (Electrolysis)
Post by 390Nut »
71Ford100 wrote:See if you can get some heavier copper or aluminum wire and try that as a conductor.
The black wire (from the charger to the electrode) is 10 gauge and is actually bigger than the charger wires are, so that wont do much I imagine. I'm looking at getting a bigger charger to try out for a day or too (25 amp, borrowed just to test it out) to see if that makes a difference.
Right now however, I'm working on my hot tank project, and figuring out if it will be feasible to buy another one of these stock tanks for electrolysis. Just need to make space in the garage to put it all together. 8)
Paul
`69 F100 390 4spd driver
